final drives
DTD 416L
final drives
Post by DTD 416L » Sat May 10, 2014 7:07 pm
can some one please tell me the final drives for
1.3
1.7
1.8
im looking at better motorway use, cheers
ps, or alternative axels mgb etc.
final drives
Post by MarinaCoupe » Sat May 10, 2014 7:39 pm
Saloon/Coupe/Estate
1.3 = 4.11:1 or late Ital 3.93:1
1.7 = 3.63:1
1.8 = 3.63:1
7cwt/440 Commercials = mostly 4.11:1 but some = 4.55:1
All 3.75" PCD
10cwt/575 Commercials = 4.55:1
4.5" PCD
MGB axles are 3.909:1 and entirely different, slightly narrower than Marina, and 4.5" PCD.
Dolly Sprint axle are entirely different again with 3.54:1 with 3.75" PCD. Also all brackets need cutting off and new ones welded one.
Re: final drives
Post by locost_bryan » Sun May 11, 2014 11:01 pm
All the small Triumphs shared the Marina diff (but not the axle housing). The 4.11, 3.89. 3.63 were also used in Spitfires and Dolomites, and a 3.27 in the GT6 and Dolomite 1850 auto. There are forum members who have fitted the 3.27 successfully.
Re: final drives
Post by ClaytonSpeed » Tue Sep 02, 2014 8:09 pm
Can someone confirm the 3.93:1 ratio and 3.89:1 and their fitments?
final drives
Post by MarinaCoupe » Tue Sep 02, 2014 8:34 pm
3.93:1 was fitted to late Ital 1.3 saloons/estates and various Triumphs.
I'm not aware that the 3.89:1 was ever fitted to Marinas or Itals, it was fitted the Spitfire Mk4 and 1500, also Dolomite 1500. I think that the 3.89:1 diff will fit the Marina axle casing, but I don't know whether the splined section will match a Marina half-shafts. The 3.89:1 crown wheel and pinion can be bought new from Rimmers for about £300 and the fitted into a Marina diff.
Re: final drives
Post by ClaytonSpeed » Tue Sep 02, 2014 8:35 pm
That's what I thought Chris. Although I keep finding references to the 3.89 diff on many internet sites :-? and nothing for the 3.93
Re: final drives
Post by MarinaCoupe » Tue Sep 02, 2014 8:39 pm
Who said the Internet was accurate? The web is worse than the proverbial man down the pub.
Re: final drives
Post by ClaytonSpeed » Tue Sep 02, 2014 8:43 pm
Obviously, but when you get 10 results with 3.89 and non for 3.93, you start asking questions..
Re: final drives
Post by MarinaCoupe » Tue Sep 02, 2014 8:48 pm
What search did you use?
Re: final drives
Post by ClaytonSpeed » Tue Sep 02, 2014 8:51 pm
Re: final drives
Post by Kilroy » Tue Sep 02, 2014 9:23 pm
At 4000 rpm the 3.27 would make a 400 rev difference over the 3.63
- that represents an extra gear.
It would make moving off slightly slower, but sounds very worthwhile for highway use.
Re: final drives
Post by ClaytonSpeed » Tue Sep 02, 2014 9:29 pm
Very true for a 1.7/2.0 or 1.8, but I'm looking at the 1.3. A little old A series may be asthmatic with a 3.27!
Re: final drives
Post by MarinaCoupe » Tue Sep 02, 2014 9:34 pm
For the difference between a 3.93:1 and a 3.89:1 you could adjust the performance by different tyre ratios.
Re: final drives
Post by ClaytonSpeed » Tue Sep 02, 2014 9:39 pm
True, But what was the 3.93:1 CWP also fitted too? Is it a real differential? ;) Can you see it listed/documented anywhere?
Re: final drives
Post by ClaytonSpeed » Tue Sep 02, 2014 9:43 pm
Plus I'm starting with a 4.11:1 on the Mk3
