Part Number Database
Post by ClaytonSpeed » Wed Jul 16, 2014 2:28 pm
Hi all,
I have started to write a part numbers database for cross referenced Marina/Ital parts. The idea is simple, you simply go to the link at the top of this page called: "Part numbers INPUT" and start listing out any cross referenced parts you may have come across that fit the Marina/Ital.
Please check the database first before adding any new entry's as we want to avoid duplications.
This is also where you can put in a part number and link it to a website that sells it.
I hope that it will grow over time and that the data it holds will be helpful now and in the future.
To view submitted data just go to the "Part numbers DATABASE" link
In time I will try and expand all the information but for now you can see a basic description and part number.
Re: Part Number Database
Post by locost_bryan » Thu Jul 17, 2014 12:13 am
Good idea. :thumbup:
Post by ClaytonSpeed » Thu Jul 17, 2014 12:55 pm
I've changed some of the parameters on the input sheet to include the various different models and engine types. Pleeeeeese have a go at adding in some information, even if you don't think it that important, it may help someone else in the future.
If you are feeling adventurous you can cross reference some parts on this site: Yoyo Parts
Post by ClaytonSpeed » Tue Jul 22, 2014 11:28 am
Having now got a new parts book I will be slowly adding useful part numbers to the database. Should anyone wish to help out and add some numbers, please help yourself..!
This could be a really useful resource for anyone who wants to find a certain part and to see what else it fits/where it can be found, and also those of us who are rebuilding cars and have lost bits along the way!
Post by Gee tc » Sun Nov 01, 2015 2:59 pm
Some panel pattern parts from SVG and Melbros should they be useful
SVG POP ON Image
Hope it might help if anyone comes across some.
T
Post by Gee tc » Sun Nov 01, 2015 3:22 pm
Gee tc wrote:Some panel pattern parts from SVG and Melbros should they be useful
SVG POP ON Image
T
I have both catalogues shoild anyone need numbers or ID for other cars.
T
Post by Morris McKinnon » Thu Dec 01, 2016 5:51 pm
I've a ton of part numbers for different makes of oil filter for the 1.3 Marina. How do I add them (if not already listed) I took a look at the form and is a bit confusing.
Post by marina12 » Thu Dec 01, 2016 6:26 pm
Thanks. Gee TC's posting of the panel sheets explains to me the differences in the fuel tanks I was wondering about between Estate and Saloon/ Coupe.
Post by Morris McKinnon » Thu Dec 01, 2016 11:45 pm
These are names and part numbers for old stock spin on oil filters for the 1.3 Marina with 5/8 UNF thread.
AC Delco: X1
Alco Filter: SP815
Bosch: 0451103267
Champion: D102
Coopers: Z93
Crosland: 670
Delphi: FX0009
Fiaam: FT4538
Fram: PH 2869
Halfords: H32
Knecht: OC19
Mahle Filter: OC19
Mann Filter: W713/14
Motorcraft: EFL 75
P.B.R: BC1107
Purolator: L27545, MF63003A
Technocar: R329
Teho: 4069
TJ Filters: FB2073, FB2074
Unipart: GFE 442
Wix Filters: WL7213
Will also fit the following vehicles...
(Austin) Sherpa Diesel (75-89); Maestro 1300 (84-92); Montego 1300 (84-89 without oil cooler)
(Bond) Equipe GT 4S (63-70)
(MG) Midget 1500 (74 on )
(Morris) Marina Van 1300 (72 on ); Ital 1300 (80 on)
(Triumph) Dolomite 1300, 1500 (76 on ); Herald 1200, 12/50, 13/60 (61-71); Spitfire 1300, 1500 (62 on ); Toledo (70 on ) 1300, TC, 1500, TC (65-76)
