Greasing prop UJ's
slughead91
Greasing prop UJ's
Post by slughead91 » Sun Mar 29, 2015 12:40 pm
I've been trying to grease all the UJ's on my prop but can't get the grease gun nozzle onto any of the grease nipples.
I ended up removing one end of the prop to get the max clearance around the nipple but still the gun nozzle wouldn't fit, it fouls on the prop itself.
Is there something obvious I'm missing here? Please don't tell me I have to disassemble each UJ and grease the cups.
And I have already wasted £13 on the sealey AK447 needle nose adaptor, which they had helpfully sealed shut during manufacture so didn't work! Quite difficult to return after the hacksaw had been out!
Cheers in advance.
Today:
1972 Marina Coupe. 1997 Rover 115SD. 1985 VW Polo breadvan. 2013 Dacia Sandero. 2001 BMW F650GS.
Previous:
1988 Porsche 944. 2004 Ford Focus ST170. 1998 Land Rover Discovery. 1994 Land Rover Discovery. 2006 Alfa Romeo 159. 1978 Series 3 Land Rover. 1998 Ford escort. 1989 VW Golf. 1991 VW T25.
Re: Greasing prop UJ's
Post by MARINAMADBAZ » Sun Mar 29, 2015 2:43 pm
Hi mate you can get the longer grease nipples which stick out further in between the yokes,ive put these on most of mine and is a lot easier then to the grease gun on.
i presume yours still has the small ones fitted
i can help out on these if you get stuck let me know
best regards
barry
slughead91
Post by slughead91 » Tue Mar 31, 2015 10:02 pm
Good call.
I'll be sure to fit those when the current ones are done.
The interim solution has been taking a grinder to my grease gun nozzle!
Today:
Previous:
Post by JubileeNut » Tue Mar 31, 2015 10:18 pm
Not sure you can leave the long ones in as they may fowl the uj. Mine have grub screws in which I remove and fit a long grease nipple to service and then replace the grub screw
