brake master cylinder
pickup-16v
Post by pickup-16v » Sat Apr 16, 2016 1:17 pm
Hi all I'm after a brake master cylinder for my pick up or something off another vehicle that will fit identically mine is a girling with the two out let's on the right side and resvoir on top looking at it on the bulk head it's the 19mm one I would like 23mm one if anyone knows to one or something a like that will do the job has I've changed to discs all round and has far to much pedal travel
Re: brake master cylinder
Post by ClaytonSpeed » Sat Apr 16, 2016 3:16 pm
SD1 is 22mm and was one I was going to look at for mine. I've not tried yet but looks similar.
pickup-16v
Post by pickup-16v » Sat Apr 16, 2016 6:28 pm
Had a look a the rover sd1 and the ports seem to be on the wrong side well the one on ebay was for mine I was looking at land rover it seems to be the right side and also looks right on the bolt pattern also it's a bigger piston inside just need to get my hands on one to see if it will work
Post by MarinaCoupe » Sat Apr 16, 2016 6:46 pm
If you are running a twin/tandem line master cylinder in your Marina/Ital, then there are a series of tandem Landrover master cylinders you could try, depending on the bore size you need.
1.00" (25.4mm) bore Girling 4008161 (Landrover GMC319 or 90577520)
15/16" (23.8mm) bore Girling/TRW 4007184 (Landrover NRC9529)
7/8" (22.2mm) bore Girling/TRW 4006200 (Landrover GMC320 or 569671)
