Colum switch broken
Brenjacques
Colum switch broken
Post by Brenjacques » Wed Apr 20, 2016 10:39 pm
Hi, the spring in my colum switch for the fog lights has broken meaning that the control jumps into then on position. I have found the part that has snapped off and just wondered if it was repairable? Does anyone also have any photos for reference? It is the mk3 type.
Cheers
Re: Colum switch broken
Post by JubileeNut » Thu Apr 21, 2016 8:24 pm
Do you mean the main beam head lights in the grill come on? If it is a MK3 are the smaller square lamps main beam driving lamps or fogs?
As far as I know fogs are not controlled on the steering column switches on any Marina?
The part can be replaced but only from another good switch!
It can't be glued as the plastic needs to be flexible and as far as I know you can't get the part separately.
Post by ClaytonSpeed » Thu Apr 21, 2016 8:25 pm
They are main beam driving lamps :-)
Post by MarinaCoupe » Thu Apr 21, 2016 8:32 pm
The little bit that has broken is made from nylon and isn't repairable. The insides of Marina/Ital/Mini/Allegro etc indicators and headlamp flashers are all the same. So if you are up to it, you can buy a secondhand unit and strip it down and then fit the nylon part to your unit.
Post by JubileeNut » Fri Apr 22, 2016 8:35 pm
I posted some pictures I think on here a while back showing the insides.
I still have the pictures here somewhere.
Post by Morris McKinnon » Fri Apr 22, 2016 8:50 pm
JubileeNut wrote:I posted some pictures I think on here a while back showing the insides.
yeh, I remember reading that, great write up and pics :thumbup:
Post by JubileeNut » Sat Apr 23, 2016 3:34 pm
