Philip
Post
by Philip » Tue May 02, 2017 8:16 pm
Hi,
I am hoping to get the original radio working in my Marina.. It's just a radio but would be nice to have something to listen to, even better if it can be adapted to accept an MP3 player!
I seem to recall that there was a member of the forum who did this, can anyone remember who??
I really don't want to replace the radio as I certainly do not want to cut the dashboard!
Any idea on price?
Thank you in advance.
1972TCCOUPE
Post
by 1972TCCOUPE » Tue May 02, 2017 9:01 pm
Josh Ward's your man for radio conversion,he'll be on soon.
Philip
Post
by Philip » Tue May 02, 2017 9:06 pm
Excellent! Hopefully Josh can help.
Now you mention his name, it was him I was thinking of!
Post
by JoshWard » Tue May 02, 2017 10:56 pm
Yep that's me
The cost is £15 for fellow Marina-ists for an MP3 input assuming the radio has a working amplifier stage (the tuner doesn't need to work). Let me know if you want to ahead with it. What radio is it out of interest? MK1s usually had a Radimobile 1070 or a Radiomobile 80.
Philip
Post
by Philip » Tue May 02, 2017 11:09 pm
Hi Josh,
Thanks for the reply.
I know it's a radiomobile, but what else, I'm not sure.
It's in the garage, removed from the car.
(I fitted another, different type, but that didn't work either. I temporarily fitted another speaker but that didn't help, so I assume I have two duff radios!!)
I will check what radio it is and let you know!
Yes, I want to go ahead!!
If it doesn't have a working amplifier, is it a lost cause??
Can you fix the radio side as well if necessary?
Post
by JoshWard » Wed May 03, 2017 7:46 am
I can have a go at fixing the radio side but I can't make any promises- it could be something really simple or it could be something wrong with the tuning arrangement and needs parts that are no longer available, I do have a good stock of spares for these though
If the amplifier stage doesn't work then we can explore other options such as fitting a modern amplifier inside the old case etc.
I'll PM you my address.
Philip
Post
by Philip » Wed May 03, 2017 9:30 am
Cheers Josh, I will get it in the post to you.
Is cheque ok? Failing that I will have to ask if my partner can pay with her PayPal account.
Post
by JoshWard » Wed May 03, 2017 10:33 pm
Either will be fine, will let you know the total including the return postage cost once it's done.
Post
by Gee tc » Fri May 05, 2017 4:22 pm
I can vouch for the standard of Josh's work.
Got one of his in my Marina.
T
Philip
Post
by Philip » Fri May 05, 2017 7:03 pm
Good to hear, thank you!
I have retrieved it from the garage.
It is a Radiomobile "80" I will try and get it posted next week.
Out of interest, what format of MP3 player will it work with and how would you go about turning it on to play the MP3s through the radio?
Post
by JoshWard » Fri May 05, 2017 7:35 pm
I fit a standard 3.5mm jack plug so can connect to any device with a headphone socket. The signal from the MP3 player is a lot stronger than that of the radio tuner so it's simply a case of tuning to the end of the medium wave band at 200 metres and pressing play on your device.
Philip
Post
by Philip » Fri May 05, 2017 8:05 pm
Thanks Josh, I can't wait!
Philip
Post
by Philip » Sat Jun 10, 2017 2:28 pm
I now have music!!
Thanks Josh!
Highly recommended.
Post
by JoshWard » Sat Jun 10, 2017 9:20 pm
Glad you're happy with it
