Marina parts
Marina parts
Ok where can I buy the following please for a LHD 1976 1.3
Exhaust front down pipe
Tie rod bushes
Jacking point
Brake Master cylinder
Any help much appreciated as have searched eBay and nothing.
Cheers
Gary
Tie rod bushes
Jacking point
Cheers
Gary
Re: Marina parts
Hi Gary, the club do very good jacking points, search Superflex for the tie rod bushes, I might have a front down pipe thats cut off under the floor and not the full piece with the silencer in. Brake master cylinders do come up on ebay especially when you put a wanted ad on here! lol.
Chris.
Chris.
Re: Marina parts
Chris on here (MarinaCoupe) does refurb Girling 75 masters on exchange. I have a spare here if you get stuck.
Re: Marina parts
Cheers Chris,have joined the club but just waiting for membership details and will order a jacking point but doubt they will have one in stock for me. Super flex it is then.The down pipe goes from the manifold and joins 3/4 along the car I think as it has a stainless one from there so would yours be ok ?.
Cheers Gareth,need one ASAP so I can get it in for mot then I can register it in the Uk will yours or (Marina coupe) ones be the same as mine as its a LHD is there any difference.
Re: Marina parts
oh yes, I forgot you'rs is LHD mk2! You may have the tandem set up fitted which is different.
Re: Marina parts
Yeah, tandem brake system. I think they used Lockheed masters.
- First-Car as Marina
Re: Marina parts
I think the one I have is similar, not sure if it's the same as I think it came from an ital. Think it was all ok when removed from the car as it was used on a banger car but I'm unsure of its actual condition, repair seals may be available but it could be perfectly fine. Let me know if that can help, I can do some more pictures if you need me too.
Alex
Alex
Re: Marina parts
I've been thinking about possible comparability with Triumph parts, since my own rhd 1800 allegedly has a TR6 servo fitted. I've just been on canleyclassics.com and they list two types of tandem master cylinder for the Spitfire 1500. I can't tell you if either are like yours but it might be worth investigating, especially if you can make out some part numbers on your old one.
Re: Marina parts
Hi first car will keep you in mind many thanks.
Re: Marina parts
Yes will try and see if any numbers can be seen.
