Marina and Allegro tandem master brake cylinders
Does anyone know if they are interchangeable? They have different girling casting numbers but apparently the same bore. This one is for an allegro, and looks exactly like the one on my '75 Canadian spec car.
Re: Marina and Allegro tandem master brake cylinders
LoOKs like a dolomite one aswell
The bore is the same, but I believe that the unions are metric on the Allegro (M10 x 1.0) and imperial on the Marina (3/8” UNF). Ask the seller to check this one.
Chris that looks the same as my one doe it not.
Gary
Gary
No Gary, that’s the same as the one that I sent you which was the wrong one. It doesn’t have the piston extension that sticks into the servo.
Thought I’d seen it
