Coupe parts
Coupe parts
Post by Kilroy » Fri Apr 10, 2020 5:28 am
Hey all.
Trust you are coping well with the enforced homestay and all in good health.
All this time at home has been moving a few projects forward a bit.
I am beginning to contemplate the rebuild of my Leyland Coupe into a Morris Coupe, so I am trying to figure out what is different between the two.
My rolling body has very few fittings in place so there are problems to be solved.
My first concern the rear side windows. I think I can source some suitable rubber which forms the inner seal, but I have no rubber inserts for the tabs on the leading edge of the chrome surround or window frame. Are these an available part from anywhere.?
Also - the stainless trim which appears to be riveted along the window aperture beneath the window itself - is there an approved method of preventing rust happening underneath it.?
It looks like a problem in waiting.
Thanks.
Re: Coupe parts
Post by locost_bryan » Mon Apr 13, 2020 9:15 pm
Hi Kilroy, good to see you're back into it.
I posted some info on the rear quarterlights here. I haven't been able to find them anywhere. Gordon in Invercargill pulled a rusty TC out of a paddock, and was able to salvage 3 of the hinge rubbers for me (the 4th one broke in half).
Skip Harris gave me a contact for someone in the states who could make them from polyurethane (iirc) fro $90, but when contacted they said they were for Austin America (2-door 1100/1300). Haven't been able to confirm if BL used the same rubbers in the Marina.
Who ever did the rust repairs on my Coupe has filled in the holes for the lower trims, so I still need to get a good panel beater to redrill the holes and figure out a way to install that will stop the rust. My parts book doesn't show anything about this trim, so don't know if there is supposed to be a seal of any sort.
Re: Coupe parts
Post by david painter » Tue Apr 14, 2020 7:14 am
Why not bond them on with Terroson 9220 it is the sort of thing was designed for I have even used it to fit rear wheel arches it not cheap but will do the job
From the Data Sheet
Teroson MS 9220 is a solvent- and isocyanate-free silane-modified polymer with exceptional bonding and sealing properties for bonding of various substrates such as stainless steel, aluminium and other metals, plastics, wood and painted surfaces. The skin formation time is 15 min. Use any type of professional dispensing tool with a piston rod for application; e.g. the Teroson STAKU HAND GUN; best application results are achieved with Teroson POWER LINE II AIR PRESSURE GUN or Teroson ET AIR GUN MULTI PRESS. Surface preparation with Teroson VR 20 recommended.
Re: Coupe parts
Post by MarinaCoupe » Tue Apr 14, 2020 8:01 am
David - I think what they are talking about are the ‘rubber’ hinges for Coupes with opening rear side windows. They had rubber hinges on the B post and catches close to where the Coupe windows come to a point. I think that they were standard on export models. I have seen them on some early TC Coupes in the UK, but most UK Coupes came with fixed glass only.
Bryan/Ken - The thundering silence from the UK end is due to nearly all UK cars having fixed windows, so we don’t get the problem that you have.
Re: Coupe parts
Post by MarinaCoupe » Tue Apr 14, 2020 8:13 am
Bryan,
You asked for UK part numbers, these pics are from the BL parts catalogue. Parts numbered “ADA” aren’t usual on Marinas, so they may we’ll have been borrowed from the 1100/1300 range.
Re: Coupe parts
Post by david painter » Tue Apr 14, 2020 8:53 am
Sorry didn't make it clear I was thinking about the lower stainless steel trims that are pop riveted to the quarter panel.
Brian put
I do think however it or a windscreen bond would work if put in the hinge slots it would stay flexible enough to allow window to hinge
Re: Coupe parts
Post by MarinaCoupe » Tue Apr 14, 2020 11:22 am
Ah OK - crossed purposes - oops
Re: Coupe parts
Post by locost_bryan » Wed Apr 15, 2020 12:11 am
Thanks for all the answers. I'll have a look for the Teroson, only found this Marina equivalent so far. Not cheap, but if it avoids drilling holes and creating potential for leaks and rust, probably worth it. :-)
Re: Coupe parts
Post by david painter » Wed Apr 15, 2020 7:21 am
It should work from the description on site says its the equivalent of industrial 9220 cost is shown as $49.99 I pay roughly £23.00 + VAT per tube in the UK
Terostat Marine Range of MS polymers are one component, rapid curing flexible adhesives and sealants for bonding and general sealing work.
These materials have high bonding strength and great sag resistance with no requirement for primers.
Terostat MS 270 (black and white):
This sealant / adhesive is the marine equivalent of the industrial Terostat 9220 and 9120.
This is a high strength polymer combining the advantages of a silicon and a urethane without the disadvantages of either. It is ideal for use on multisubstrates with no need to prime on to aluminium, steel, stainless steel, brass etc. UV and salt resistant - ideal for the bonding and sealing of fittings and to glass etc.
Upol also make a Similar product in the UK I have not used it personally but I am told it is good by those that have would be able to use it on the lower stainless trims though Euro Car Parts have it listed on their site for £8.99 inc VAT
TIGER SEAL POLYURETHANE SEALANT AND ADHESIVE
TIGER SEAL™
A one component ready to use polyurethane sealant and adhesive that bonds to most materials including steel, aluminium and most plastics. Ideal for sealing and bonding body panels, trims and seams.
Non shrinking
Permanently flexible
Can be overpainted
tiger seal.jpg (34.34 KiB) Viewed 4849 times
Re: Coupe parts
Post by Gee tc » Wed Apr 15, 2020 11:01 pm
I've used tiger seal on mine in places.
The LE models had opening rear windows too. Ours did.
