prop shaft
john curvis
prop shaft
Is the early Marina prop shaft similar to the Ital i.e. has a center mounting or is it just one piece thanks
Re: prop shaft
The are interchangeable.
john curvis
Re: prop shaft
So both have a center mounting
prop shaft
Yep. I think only van and pickup are different but only in length. Centre bearing / two piece prop on all Marina and Ital’s.john curvis wrote:So both have a center mounting
Re: prop shaft
David is correct, only 10cwt/575 Commercials (Vans & Pickups) have a slightly shorter propshaft. All Saloons, Estates, Coupes and 7cwt/440 Commercials share the same two part propshaft and centre bearing - all models, all years.
trunnions ftw
Re: prop shaft
Is it shorter due to the longer nose diff?
Re: prop shaft
Yes exactly, the 10cwt/575 commercials uses different heavy duty back axle, the so called banjo axle. As you surmised the diff ff nose is longer than the saloon etc. axle.
