prop shaft
john curvis
prop shaft
Post by john curvis » Sun Aug 29, 2021 5:07 pm
Is the early Marina prop shaft similar to the Ital i.e. has a center mounting or is it just one piece thanks
Re: prop shaft
Post by ClaytonSpeed » Sun Aug 29, 2021 6:05 pm
The are interchangeable.
john curvis
Re: prop shaft
Post by john curvis » Mon Aug 30, 2021 4:26 pm
So both have a center mounting
prop shaft
Post by balmy » Mon Aug 30, 2021 5:18 pm
john curvis wrote:So both have a center mounting
Yep. I think only van and pickup are different but only in length. Centre bearing / two piece prop on all Marina and Ital’s.
john curvis
Re: prop shaft
Post by john curvis » Mon Aug 30, 2021 8:23 pm
thanks for your help
Re: prop shaft
Post by MarinaCoupe » Tue Aug 31, 2021 1:00 pm
David is correct, only 10cwt/575 Commercials (Vans & Pickups) have a slightly shorter propshaft. All Saloons, Estates, Coupes and 7cwt/440 Commercials share the same two part propshaft and centre bearing - all models, all years.
trunnions ftw
Re: prop shaft
Post by trunnions ftw » Tue Aug 31, 2021 6:22 pm
Is it shorter due to the longer nose diff?
Re: prop shaft
Post by MarinaCoupe » Tue Aug 31, 2021 10:09 pm
Yes exactly, the 10cwt/575 commercials uses different heavy duty back axle, the so called banjo axle. As you surmised the diff ff nose is longer than the saloon etc. axle.
