Can I borrow (or steal) your arm ?
I'm wanting to fit a roll bar to the front of my Mk1 Coupe...
I need a later lower arm so that I can mark where to drill t'ole! (I'm from Yorkshire, sorry)...
Have peope done this? Is it the best way... etc.
Rob
Rob
- northeastmarina
HI,
Ive been slowly getting all my bits together over the last few years and plan to polybush the entire car, ep90 dampers, and have got new coil over rears. All new joints, trunnions and completely rebuilt brakes of course will be fitted. I'm not sure I want to modify the bodywork to accept anti-roll bars unless I really have to.
I'll get a telescopic kit and roll bars when funds allow unless the first phase doesnt work as well as I hope for.
I had these coil overs on my original '72 Marina 25 years ago and it did handle quite well at the back but the front was a bit soggy compared to the LE's that my dad had.
Starting this winter as I should finally have some time to do so.
Tony
Tony
The anti-roll bar (ARB) passes through the bracket below the chassis rail behind where the Tie Bar mounts to the chassis.
The ARB body mounts bolt up to the bracket. When Paul Mondey did my bodywork recently, I got him to cut the slots required to mount the ARB. However on talking with Paul Viney, when Frank did his bodywork on his Jubilee, they had to fit a new chassis section and this had the later slotted mount. To fit the ARB you really only need to have one side slotted as you can slip the other side through the mounting hole.
I'll take some pics in the next few days, so that you can see what I mean.
On v early Mk1s, there isn't enough bracket to mount the ARB, obviously at that time they weren't thinking of having ARBs at all.
Hi Rob here's a picture of lower arm if it's any good to you,
the measurement for the ARB hole shows 45.59mm the left hand hole being the ARB hole.
This pic hopefully shows the Chassis bracket which needs to be "slotted"to allow ARB to fit.
Hope this proves helpfull, any other pics you want need just let me know.
Steve
Steve
Ital Pickup, now that's a real mans transport
1983 575 Green Ital Pickup Daily driver
1983 575 Blue Ital Pickup Under Resto
1983 575 Blue Ital Van Rolling Resto
