Post
by MARINAMADBAZ » Sun Feb 07, 2010 8:40 pm
Hi
had a go at cleaning and re-painting some decent leaf springs and fitted superflex spring bushes,wondered if anybody had also tried superflex bushes and do they give better results?
primed
painted
superflex bushes fitted
Best regards
Barry
Ausmarina
Post
by Ausmarina » Mon Feb 08, 2010 12:04 am
I haven't used superflex but have used other plastic bushes(Urethane) in the springs and shackles. Much firmer and tighter rear end is what you get. They even raised the rear of the car about half an inch. Just showed how shot the rubber was. At the time I had adjustable Koni shocks and I needed to adjust them up to control the rear of the car.
Graham.
Brisbane, Australia
74 Leyland P76 4.4 V8 (working on it now!!)
73 Leyland P76 2.6 6 (work in progress)
77 MK2 Morris Marina HL (work in progress)
07 Ssangyong Actyon Sports (it actually works)
Post
by MarinaCoupe » Mon Feb 08, 2010 9:58 am
Barry
I hope that's not the living room carpet, or you are in big trouble.
Post
by JubileeNut » Mon Feb 08, 2010 10:10 am
I thought that as well, but if its the garage its a bit posh
Post
by MARINAMADBAZ » Mon Feb 08, 2010 10:52 pm
Thanks guys,no that's not the living room carpet the other half wont let any car parts through the front door. :|
the garage has an old carpet down fully covering the garage floor
Best regards
Barry
MARINAMAN480
Post
by MARINAMAN480 » Tue Feb 09, 2010 6:14 pm
Where can you get the superflex bushes from they would be quite handy for my coupe
Post
by locost_bryan » Tue Feb 09, 2010 9:05 pm
MARINAMAN480 wrote:Where can you get the superflex bushes from they would be quite handy for my coupe
Motorsport World or
Superflex
Ausmarina
Post
by Ausmarina » Wed Feb 10, 2010 2:17 am
Graham.
Brisbane, Australia
dazza2623
Post
by dazza2623 » Sat Mar 06, 2010 3:25 am
Trust the Aussie to focus on the porn ads.
I did not use urathane bushes in the rear as I was told it made things too harsh,I just replaced them with new Leyland ones.
I wasn't disappointed with the result.
Marina 6 one day,V8 the next
Ausmarina
Post
by Ausmarina » Sat Mar 06, 2010 4:29 am
A bit harsh is probably the way i'd put it also. I don't know if the standard shocks would be able to control rear but i suppose it would depend on how strong the springs are as well.
Graham.
Brisbane, Australia
Post
by Kilroy » Sun Mar 07, 2010 7:53 am
My observations are thus;
Superflex (UK) were so amazingly prompt that I had my parts here in NZ 4 days after ordering.
Thats big.
The polyurethane bushes are quite supple, and the car that I have put all poly bushes in is the most compliant suspension I own..!
Top marks there.
The bushes supplied were purple - I believe that the density of the bushes is related to the colour.
In future I will use nothing else.
Post
by locost_bryan » Mon Mar 08, 2010 1:10 am
Did you change anything else in the suspension at the same time? If not, then sounds like a great improvement!
Does the car handle better as well? How worn were the bushes that were replaced?
Post
by Kilroy » Mon Mar 08, 2010 8:10 am
Besides fitting Poly eyebolt bushes, radius rod bushes, rear spring shackle bushes - I also lowered the car by 1" with blocks at the rear, and adjusted torsion bars at the front.
Reconditioned front shocks were also fitted.
However - I have done most of this to a number of cars before - its just that this time it all feels far more supple and without any knocks or rattles.
The original radius rod bushes and shackle bushes looked very much worse for wear - the eyebolt bushes looked ok - but I feel that this is where most of the improvement comes from.
Handling is probably improved - its just not a car that lends itself to testing the limits...
