Citron Yellow
Citron Yellow
I just want to paint everything this colour now.
Re: Citron Yellow
looks a bit like an australian leyland colour called
HAIRY LIME
as used on Mini, Marina and P76 in AUS
HAIRY LIME
Re: Citron Yellow
At least you will know if someone does not see you coming in that they are blind 8)
Did you not remove the bonnet catch!?
Lovely finish
Lovely finish
Re: Citron Yellow
I removed the bonnet catch, painted it then screwed it back on, by the time I got home, my friend had masked it off. I figured it wouldnt do any harm to stay on. Its not going to be a showstopper, just a low budget "something different"...
Re: Citron Yellow
Details for Citron from Paul Tegler's MG site
* BMC/BL BLVC 73
* Ault & Wiborg/- Berger/Gipgloss AWBG 30083
* ICI ICI 8653
* PPG/ Ditzler (US) DITZ 44947
* Dupont (US) DUP 43276
* Glasso/Rinshed Mason (US) RM 6669
* special and non US color information RM BM177
Hairy Lime is shade # 15571 in the Dulux range. So the number you are looking for is 566-15571.
* BMC/BL BLVC 73
* ICI ICI 8653
Re: Citron Yellow
That green is more like the UK snap dragon I think. I have seen Itals in this similar colour but citron is more yellow but when seen against a real yellow it looks more green!
May Avatar when it shows the TC Jubilee unfolded it is Citron, sampled from a photograph. but then it folds up and goes loads of colours.
Re: Citron Yellow
locost_bryan wrote:Details for Citron from Paul Tegler's MG site
* BMC/BL BLVC 73
* ICI ICI 8653
Is that a Leyland P76?? I WANT ONE!!!!!!
Re: Citron Yellow
yep that is a P76 in super trim, odds on it is a 4.4 litre V8
instead of the 2620cc 6cyl 'E' series
Re: Citron Yellow
Cheers, looks really nice, I wish they sold them here.. 4.4 V8 eh.. That isn't the Rover V8 then is it? That was only a 3.5 in those days, was it a BL V8 or from another manufacturer?
Re: Citron Yellow
They are a modified version of the rover 3.5. Stroked to be a square bore and stroke of 88.9mm. Deck hight increased, manifold and timing chain and water pump different. 192hp 285 lb/ft in a car weighing in at about 1280kgs(2830lbs)Philip wrote: 4.4 V8 eh.. That isn't the Rover V8 then is it? That was only a 3.5 in those days, was it a BL V8 or from another manufacturer?
Graham.
Brisbane, Australia
74 Leyland P76 4.4 V8 (working on it now!!)
73 Leyland P76 2.6 6 (work in progress)
77 MK2 Morris Marina HL (work in progress)
07 Ssangyong Actyon Sports (it actually works)
Brisbane, Australia
Re: Citron Yellow
Is that all they weigh?? They look enormous!
Re: Citron Yellow
Yes!! It is amazing how much weight you can save if you start with an aluminium v8 and build a car around it.Philip wrote:Is that all they weigh?? They look enormous!
And yes again, they are a big car. You can open the boot and put a 44 gallon drum, on it's side, into it and close the lid. Not too many cars can hold that much. :shock:
Graham.
Brisbane, Australia
Brisbane, Australia
- Alan The Exocet
Re: Citron Yellow
The green colour shown on the Leyland P76 is nearest too (in the Austin Rover car range) is Apple Jack (BLVC228) and used on Ital's,Mini's and Allegro's.Snapdragon was a bright sun yellow (BLVC235) and used on Ital's,Mini's,Allegro's,Princess and MG Midgets/B/BGT.
Alan
Alan
Re: Citron Yellow
Yep that's the colour Apple jack. Now you have said it I remember now
Re: Citron Yellow
the P76 V8 was also used in what I would call a light truck (Leyland) :shock: that is up to
8 ton/tonne all up.
very strong engine that makes range rovers go LOTS better
8 ton/tonne all up.
