Shaking at 50
Shaking at 50
Hi
My marina drives ace , till I get the 50 then the steering shakes , after 50 it is fine.....
Balanced my wheels and its not a ball joint etc....
any ideas?
also has anyone fitted a fan switch that has different speed settings?
any ideas?
Sounds like tie bar bushes! Get onto Superflex and find some replacements! www.superflex.co.uk
When you say fan speeds do you mean the blower fan?
Yes the blower fan ,its a bit noisy and a slower speed would be great....rexxtherunt wrote:Sounds like tie bar bushes! Get onto Superflex and find some replacements! www.superflex.co.uk
tie bar ,is that the same as anti roll bar?
oooops thanks...
Dandaz, the superflex part number is: SPF0669 you will need 4 of them.
As for other reasons it could be the rack. I had the same problem as Paul and I replaced the rack for a genuine one and it certainly helped. Also bearings have an effect too. Make sure they aren't worn and slack/over tightened.
The other area I looked into was my Ital top arms.. Now obviously Mk1's don't normally have these so that was more on my own car but If you do have them fitted for a telescopic conversion then always check.
- Clan Chieftain
