How well does your car run?
- marinastevie
How well does your marina or ital run?the last two shows ive been at my marina1.7hl has had fuel overflowing from the carb,resulting on me being recovered from southwaite services to glasgow last sunday after the national.today after fitting a new needle/seat it did it again just not as bad.any help with this would be appreciated/or if its happened to you before .the carb is a FZX1315
WWW.MORRISMARINAECOSSE.COM
SCOTLAND'S 1 AND ONLY
Chicken Hawk
I had the same problem on my Mk1 1.8 single carb the petrol was coming out through the top of the float chamber breather. It was as it's worst when ticking over or low revs rather than in normal driving.
After a strip and clean in carb cleaner it all worked fine. The only thing that I found was a minute particle of c**p had lodged between the petrol inlet and the float mechanism, sticking the float down (holding the float valve open).
Since then I have fitted an inline filter between the pump and the carb and it hasn't happened again. I run with a non-standard carb needle for two years without any other problem.
- Clan Chieftain
carbs.
stevie with yours being a 1700 you cant take the top off you need to take the carb off. then you throw it in the bin along with your "o " series engine and fit a much better 1300 engine and box preferably from a morris minor that has been upgraded.
........clan chieftain
