Rear axles
- MARINAMAN480
Rear axles
Quick question what other cars share the same rear axle as the marina/ital
The ones that spring to mind are
Dolomite
TR7 4speed
Some Caterham 7's
Reason i ask is that a friend of mine writes for classic monthly and we have done an tech peice on changing rear wheel bearings so need to get article correct
Dolomite
TR7 4speed
Some Caterham 7's
Re: Rear axles
Hi Lee,
Possibly spitfire/herald/vitesse/GT6 as well, check out the wheel bearing kit number for say Dolomite on RimmerBros and it will show you all its uses at the bottom of the page.
I look forward to seeing the article, which edition will it be in? Does my hub puller get a mention?
- MARINAMAN480
Re: Rear axles
Cheers chris
Your puller should have its picture in the mag not sure which edition yet .
Re: Rear axles
Lee,
Don't forget to mention that there are two sizes of rear axle oil seals (early/late), if its appropriate.
- MARINAMAN480
Re: Rear axles
Yep already done with photographic evidence of the 2 different hubs
