Rear axles
MARINAMAN480
Rear axles
Post by MARINAMAN480 » Sat Dec 13, 2014 7:38 am
Quick question what other cars share the same rear axle as the marina/ital
The ones that spring to mind are
Dolomite
TR7 4speed
Some Caterham 7's
Reason i ask is that a friend of mine writes for classic monthly and we have done an tech peice on changing rear wheel bearings so need to get article correct
Re: Rear axles
Post by MarinaCoupe » Sat Dec 13, 2014 10:47 am
Hi Lee,
Possibly spitfire/herald/vitesse/GT6 as well, check out the wheel bearing kit number for say Dolomite on RimmerBros and it will show you all its uses at the bottom of the page.
I look forward to seeing the article, which edition will it be in? Does my hub puller get a mention?
MARINAMAN480
Re: Rear axles
Post by MARINAMAN480 » Sat Dec 13, 2014 3:10 pm
Cheers chris
Your puller should have its picture in the mag not sure which edition yet .
Re: Rear axles
Post by MarinaCoupe » Sat Dec 13, 2014 3:51 pm
Ah fame at last!
Re: Rear axles
Post by MarinaCoupe » Sat Dec 13, 2014 4:13 pm
Lee,
Don't forget to mention that there are two sizes of rear axle oil seals (early/late), if its appropriate.
MARINAMAN480
Re: Rear axles
Post by MARINAMAN480 » Sat Dec 13, 2014 4:38 pm
Yep already done with photographic evidence of the 2 different hubs
Re: Rear axles
Post by MarinaCoupe » Sat Dec 13, 2014 5:10 pm
Nice one.
