Flat Spot
LORENZO73
Re: Flat Spot
Post by LORENZO73 » Wed May 13, 2020 5:34 pm
MarinaCoupe wrote: Wed May 13, 2020 3:20 pm Hi Renzo,
I have checked your teeth count and recalculated the gear ratios with the aid of a spreadsheet. Initially I got the same answers as David Painter. These are clearly wrong. However, I think that you have written down the teeth count for the second and third gear Mainshaft and layshaft the wrong way round, so if you write
Second gear as Laygear 21 and Mainshaft 26 then the calculation comes out exactly right at 1.92:1
Equally for third gear as Laygear 25 and Mainshaft 21 then the calculation comes out exactly right at 1.31:1
So this is a 1.8 gearbox - its an easy mistake to make.
Hi chris, and david,
Many thanks for help, i am so happy that i know more, about my car.
Next step, what do you thing chris? :crazy:
Re: Flat Spot
Post by locost_bryan » Wed May 13, 2020 9:29 pm
Looks like Renzo just needs to get the correct speedo drive gear for the 3.63 axle.
Could be useful to have a chart pinned in the tech thread that lists the gearbox and diff stuff all together - the gear tooth counts and ratios, the standard combinations, rpm vs speed for standard tyres, speedo drive gears, etc.
Re: Flat Spot
Post by david painter » Wed May 13, 2020 10:08 pm
Chris and myself have spent a long time sorting them out his spread sheet is good I have learnt a lot myself while working this one out spent ages looking at part numbers and cross references
Re: Flat Spot
Post by locost_bryan » Wed May 13, 2020 11:04 pm
Would be good to pin it in a thread in the tech section for future reference. :ugeek:
LORENZO73
Re: Flat Spot
Post by LORENZO73 » Thu May 21, 2020 2:55 pm
Speedo and reefs now ok , with the gear of 20 teeth that he send me chris, many thanks .She comes like an original 75kpm with 2500 rpm on the fourth gear.
So now the difference is camshaft for much power.
Renzo
Re: Flat Spot
Post by david painter » Thu May 21, 2020 4:22 pm
Just run Calculations actual speed 46.60 MPH equivalent Calculated Speed on 3.63 diff with 155r13 tyres is 46.64 MPH so Speedo now reads Spot on you should be well happy now
LORENZO73
Re: Flat Spot
Post by LORENZO73 » Fri May 22, 2020 2:35 pm
Yes David, i am very happy , because i know that my marina have diff and gearbox for 1.8.
The difference that she have is camshaft, i would like to tell, you and chris, big thanks for help to change it.
Renzo
LORENZO73
Re: Flat Spot
Post by LORENZO73 » Sun Jun 28, 2020 10:45 am
. I put the revolution rims, and I lower it 2 inch. Renzo
Re: Flat Spot
Post by JoshWard » Sun Jun 28, 2020 10:49 am
That looks great!
LORENZO73
Re: Flat Spot
Post by LORENZO73 » Sun Jun 28, 2020 8:10 pm
Thanks josh
Re: Flat Spot
Post by PHUQ » Sun Jun 28, 2020 9:55 pm
Liking that a lot Renzo, very cool.
Re: Flat Spot
Post by locost_bryan » Sun Jun 28, 2020 10:59 pm
Nice :thumbup:
Re: Flat Spot
Post by Gee tc » Sun Jun 28, 2020 11:50 pm
LORENZO73 wrote: Sun Jun 28, 2020 10:45 am 40F3B58F-7207-4B9E-9BB6-59876688B070.jpeg. I put the revolution rims, and I lower it 2 inch. Renzo
I remember seeing possibly this car just outside Valetta back in 2015
I was on a tour bus so didn't have time to snap it.
If it's the same one... it looked immaculate!
SLOW ITAL
Re: Flat Spot
Post by SLOW ITAL » Tue Jun 30, 2020 9:05 am
looking very good Renzo...Gil
Re: Flat Spot
Post by Kilroy » Thu Jul 02, 2020 9:57 am
