morris marina?
jean philippe 84320
morris marina?
Post by jean philippe 84320 » Thu Sep 19, 2024 2:49 pm
Hello
I have a Marlin with a morris marina 1300 engine with the engine number12V 639 EH 259084. Can you tell me which marina it is from?
Re: morris marina?
Post by MarinaCoupe » Fri Sep 20, 2024 6:35 pm
It’s from a late Mk1 1.3 Marina.
jean philippe 84320
Re : Morris Marina ?
Post by jean philippe 84320 » Sat Sep 28, 2024 11:57 am
Hello, is my 12V259084. 639 engine a van or a pick-up truck?
Re: morris marina?
Post by MarinaCoupe » Sat Sep 28, 2024 2:13 pm
Your engine is more likely to have come from a saloon/coupe than a commercial. The letter ‘H’ in the code indicates high compression pistons 8.8:1, an ‘L’ would indicate low compression pistons 8.0:1. If your engine has been rebuilt previously, then there’s no guarantee that high compression pistons were used if they were replaced.
A compression check on a good low compression engine should show about 150psi.
A compression check on a good high compression engine should show about 170psi.
