Body plate
ste
Body plate
Post by ste » Tue Jul 29, 2008 10:20 am
Having become a new owner of 2 coupes in NZ, one 72 for parts and a 72 TC to put on the road, can anyone tell me where the body/chassis identification plate is please?
They are both Australian models with the 1750 motor.
Post by MarinaCoupe » Tue Jul 29, 2008 2:12 pm
On UK cars, the chassis plate is on the slam panel for the bonnet on the left hand side as you lok at the front of the car. It may be different on Aussie cars, maybe one of our Australian members can confirm?
Or Jan-Ivar if he reads this?
Ausmarina
Post by Ausmarina » Sat Aug 02, 2008 3:05 am
In Australia they are on the complience plate. Straight out of the book.....
It is located under the bonnet, topside of the left hand guard valance. (if that makes sence). But you are in NZ and as far as I know , you don't get a complience plate!! I don't have an Aus built Marina at the moment but I can remember there being a no stamped to the left of the battery.
Graham.
Brisbane, Australia
Post by norway_triumph » Mon Aug 04, 2008 8:59 pm
correct Graham :)
plate is LH on Firewall top and also the serial is stamped on the innerwing behind the battery.
ste
Body plate
Post by ste » Sat Aug 16, 2008 11:05 am
Thanks guys. Found the number, or should I say the remains of it. It's blurred by surface rust and I can't read it. Never mind.
Any NZ members with a set of Rostyles out there?
Post by Kilroy » Sat Aug 16, 2008 8:57 pm
Not here sorry - but I imagine you and I may have different stud patterns anyway.?
My UK models have a very narrow stud pattern, shared by only a few other makes.
If yours also measure 3.75"pcd then Triumph Spitfire/GT6 rims will bolt on.
Another option is to have your steels widened - Elite Wheels in CH do them for $45 a corner - had mine taken to 7" - no balance problems.
You can also get Superlites drilled to suit by Performance Wheels in Hamilton, but they will cost about a grand.
http://www.performancewheels.co.nz/performance.html
Fairly critical that you maintain the original offset, as there is not any spare room behind the rims at the front - only the 13x7 in the middle of the webpage is suitable as 7" fit - with 7N offset = deep dish.
My choice is 7" using 205.60/13 tyres of any description - they are only $100 each right now.
If you view the vehicles in my garage on this site you will see several examples of both wheels.
Cheers,
ste
Rostyles in NZ
Post by ste » Sun Aug 17, 2008 12:55 pm
Thanks for the advice. I've seen your webpage Your cars look great!!
My boy agrees with you re the other wheels. I like the rostyle look. Something will turn up. The car has a fair few things to do before it hits the road,
ste
Rostyles in NZ
Post by ste » Sun Aug 17, 2008 12:57 pm
And yes, your wheels and mine are different stud patterns.
Post by MarinaCoupe » Sun Aug 17, 2008 7:55 pm
The Aussie stud pattern was the same as Ford (Leyland used a Ford back axle), so Ford Rostyles of a Mk2/Mk3 Cortina should fit if you can find some.
Please measure the PCD first before buying, in case I am talking out of my ar**.
