Ignition and door locks - and keys
Fille
Post by Fille » Mon Jul 06, 2009 1:08 pm
I have only got one set of keys for my TC, and these keys are not original - ie no marks or numbers on them. Can anyone advice where I could get hold of a new set of locks, preferrably with keys ;) or if there is some way of getting original keys to my current locks.
1973 Morris Marina 1,3 Coupé
Re: Ignition and door locks - and keys
Post by JubileeNut » Mon Jul 06, 2009 5:07 pm
Hi, I bought 2 blank ignition keys from here! Ebay Item number: 250427950928 I think they came all the way from the USA.
It is worth e-mailing him as this item number is probably wrong but if you send details or pictures of your key end on etc may have the right blank. You then need to get them cut to your original key for the ignition.
Then I re-levered the glove box to fit this key.
Then I bought a new door handle with two keys (Original Leyland ones and re-levered all the other locks to these.
They do come up on ebay but not normally a set for ignition and doors as far as I know.
Cheers,
Fille
Post by Fille » Mon Jul 06, 2009 8:17 pm
Thanks Paul,
I presume we have the same type of locks, right? Do you remeber or have any reference as to what type of key it was? I have emailed the seller and he does not know straight away which type it is. It can be BL, AA, MG or RV coded... I ttried taking pictures of my keys but it is really difficult to take pics of keys! :roll:
Post by JubileeNut » Mon Jul 06, 2009 10:49 pm
These were the pictures I sent the chap!
Was a while ago now and not sure if you have the same lock on the ignition.
It was only the ignition key I got from this guy.
The door keys were always different to the ignition.
Check these against your keys and ask him if he can do this type!
Hope this helps,
Post by locost_bryan » Mon Jul 06, 2009 10:59 pm
Have a look at the key pics/diagrams here. And check out their code helper.
AA3 is listed for Marina 79-84. FS Generic FS Key - The most commonly used key used by British car manufactures (Mini, Triumph, MG etc). For: British Leyland - MG, Land Rover, Triumph, All Mini doors and early ignition and many more.
FS Key cut to code - Supply the three digit code and we will cut a brand new blank to your correct code.
No more duplicating worn out keys - these are cut to the original shape. You must supply the code taken from your old key or lock - it will be FS??? what we will need is the three numbers after FS. (cross section of key is the hole that the key goes into) Click on line drawing for photograph.
Codes run from FS001-FS099 and FS876 to FS955
KEY-FS(Specify three letters)
Cross referenced as:
Ilco #: 62FS
Dominion #: 62DR
Taylor #: S71B
Curtis #: UN18
Silca #: UNI11A
Star #: UN3
OEM #: Union
Need help finding your cars lock code - code helper
