Anyone knows what this is for?
Post by JubileeNut » Sun May 09, 2010 9:22 am
This was in the boot of my car when I got it and I think it is part of the tool kit but no idea what its for!
Hub cap puller is the only thing I can think of but I have no hub caps to pull on a Jubilee!
Also I have a similar item in black which is like a tiny crow bar with a over 90 deg bend at one end which has a sharp edge and made from thicker gauge material but about the same length as this silver one.
Any ideas?
vermillion
Re: Anyone knows what this is for?
Post by vermillion » Sun May 09, 2010 9:58 am
It looks like a stereo removal key Paul but why you would have one of those in a Marina tool kit I have no idea :roll:
mk2 golfer
Post by mk2 golfer » Sun May 09, 2010 10:17 am
It looks like a computer blanking plug thingy, the thing you have to remove at the rear of your pc if you want to add a graphics card for example
Paul
robb9900
Post by robb9900 » Sun May 09, 2010 10:55 am
Thats what BL supplied to get the hub caps off, got a few around if anyone wants one. If I remember rightly, they were not much use.
rOBB
Post by JubileeNut » Sun May 09, 2010 7:20 pm
Well the 2 ideas you have had are good. As for the computer blanking plate although it does look like one this is a heavier gauge metal and no hole to screw in!
Plus it is a lot wider than a stereo removal key!
So I think it must be a hub cap puller but no good for a Jubilee as the hub cap goes on with the 4 wheel nuts!
Strange thing is the other item I have which is similar probably is also a hub cap puller :roll:
Still I have cleaned and painted it and will carry it as I may have other uses for it :wink:
stuthegasman
Post by stuthegasman » Sun May 09, 2010 10:30 pm
definately a hubcap puller i've had one in all the marina's i've had and the same in an Allegro I owned as well so yes they were standard BL issue
marinast
Post by marinast » Sun May 09, 2010 10:57 pm
These are useless as they damage the wheel finish when you try to remove the hub cap with them.
Post by MarinaCoupe » Mon May 10, 2010 10:02 am
Yes BL designed them to scratch the paint surface and break through the chrome on the edge of the hub cap.
