Thermostat Housing
Thermostat Housing
There's a bolt down the middle of the top of the thermostat housing on my Ital- engined 1.3 Marina
or rather there was...
Any ideas for me?
Should I just try get a new housing or can the bolt be obtained?
Thanks in advance
Any ideas for me?
Thanks in advance
Re: Thermostat Housing
Buy one of these instead, you will never have to worry again...
http://cgi.ebay.co.uk/Land-Rover-TDi-Ra ... 4152773697
- MARINAMAN480
yep nice one good idea. i once used a 1/2inch bsp black plug from my plumbing stuff.
Nice one marinacoupe- ordered from eBay - didn't see the landrover thingy...
Hopefully it'll do the trick!
Thanks again
Mick
Thanks again
Mick
i found a brass one years ago and keept it for every one of my marinas the pich is bsp if that helps
plus did they put that housing on the 1800 its just i need one now as the rad i have just fitted is lower and the high ponit is the top of the block :?
Thermostat Housing
They didn't use them on the 1800 marina but as they used them on the mgb you should be able to fit one of those. Be careful though some outlet pipes go the wrong way and as you know the housings only fit one way
