1,3 Air filter
1,3 Air filter
I have a problem sourcing a new air filter for my 1,3 (-73). The "normal" motor factors don't list these any more and the specialist around here says that he can't get hold of any air filters for the 1,3 any more - apparently noone makes them? I also did a quick eBay search and I while I found a few that looked right, they were listed as fitting the 1,3 only from 1978.
Any suggestions?
Any suggestions?
1973 Morris Marina 1,3 Coupé
Re: 1,3 Air filter
How about a basic aftermarket filter ? I'm using a "SIMOTA" Mushroom filter on my 1.8. Simply clamps onto the air intake.
If you want an original, I have no idea.
if you ever see Jeremy Clarkson, drop your marina on him.
mk2 golfer
Re: 1,3 Air filter
Hey Joe, like the air filters, where do you get them from?
Paul
Re: 1,3 Air filter
I will try to keep it as original as possible. Will visit my motor factor with the old filter and we'll try to find a close match. But really, surel there must be someone over in the UK with a stockpile of these filters?
andrewwita
Re: 1,3 Air filter
if you cant find one you could try collectors car parts heathrow
43/45 Sipson Way Sipson, West drayton, Middlesex UB7 0DW - 020 8897 3774
His shop is amazing - such a variety of stock - where when i have been in there for parts - you have to hunt thru boxes upon boxes of stuff
he has shelves of new old stock items .
Re: 1,3 Air filter
I got mine off Trademe, which is like a NZ ebay. But you can get them over there...mk2 golfer wrote:Hey Joe, like the air filters, where do you get them from?
see : http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
Re: 1,3 Air filter
The standard air filter for Mk1 & Mk2 Marina 1.3s and 1.8 single carbs is the Unipart GFE 1005 - available from some motor factors and listed currently on EBay. http://stores.ebay.co.uk/blacksofstichi ... =398740919
Also listed for Triumph Dolomite single carb so available via Rimmer Bros - about £5.00.
Re: 1,3 Air filter
Yep, I have seen both those ebay listings but in the description it says 1,3 only after 1978?
- The General
Re: 1,3 Air filter
they are still available of the shelf, ill get you some part nos tomorrow if u want them for a few different suppliers.
Re: 1,3 Air filter
Hi Fille,
I checked the BL Part No. from original BL Marina parts catalogues
Re: 1,3 Air filter
Yes please!The General wrote:they are still available of the shelf, ill get you some part nos tomorrow if u want them for a few different suppliers.
Re: 1,3 Air filter
Found some in the US! British Parts Source in Ohio sent me 2 x GFE 1005 in ORIGINAL BOXES!
Unipart doesn't make these anymore do they? Fram do not make their equivalent CA646 any more.
