Ben's got shiney nuts!!
billytits
Post by billytits » Thu Nov 15, 2007 10:59 pm
Thought you might wanna have a look at ben's new nuts
www.morrismarina.org.uk
billytits
Other shiney bits I've made
Post by billytits » Thu Nov 15, 2007 11:01 pm
Post by JIM73 » Thu Nov 15, 2007 11:04 pm
Very shiney Trev !! :wink:
Post by ClaytonSpeed » Fri Nov 16, 2007 9:55 am
lovely!!! I look forward to fitting these! Thanks Trev!
Post by ~Sam~ » Fri Nov 16, 2007 11:00 am
don't suppose you have another 16 mine are all knackered :lol:
billytits
Post by billytits » Fri Nov 16, 2007 10:23 pm
Sam what wheels are you running as i will need to make a drawing so that i can reproduce them accuratly
Post by JIM73 » Fri Nov 16, 2007 10:25 pm
Standard TC nuts !! like the ones you were making me 2 years ago !! :roll:
billytits
Post by billytits » Fri Nov 16, 2007 10:35 pm
Looks like I've got a big batch to make then! Don't get gobby or you'll get nothing ginger pink thing!!
Post by JubileeNut » Fri Nov 16, 2007 11:15 pm
Trev, are those wheel nuts stainless?
Only I need ones like those but not same as standard TC as the Jubilee has a centre cap and a flat plastic washer on the wheel nut!!
Not easy to find these ones, well so far!
Cheers,
Paul
Post by Gee tc » Sat Nov 17, 2007 10:05 am
HI ,
Paul......
If the jubilee uses Triumph centre caps, Will their nuts do?
(not that I have a clue how they look!)
Tony
Post by JubileeNut » Sat Nov 17, 2007 3:54 pm
Hi Tony, like the avatar / picture :wink:
Spitfire or GT6 wheel nuts are the same!
they have a plastic washer on the nut to protect the centre cap :wink:
I have some spare ones I bought but they are second hand and not in great condition.
I think I can get new ones from rimmer bros but they cost lots!
Still no news on Harleys place yet! I think she must be snowed under with bits to sort or they are dragging their heels! :cry:
Hope you car is going well, mine is stripped now.
Cheers,
paul.
billytits
Post by billytits » Sat Nov 17, 2007 11:13 pm
hi paul
stick a pici on and i will let you know if i can sort something out and yes they are stainless i think ive got a bit of a fetish for the stuff if i can make them we will talk about cost later on but im sertainly not rimmers
cheers
Trev
Post by JubileeNut » Sun Nov 18, 2007 11:14 am
Hi Trev,
I will get a picture up here -
This was off ebay as I have no access to my pc at mow, but this is what they look like!
billytits
Post by billytits » Mon Nov 19, 2007 9:57 am
hi paul
they should be no problem will need some sizes i presume the nuts are the same as a tc nut but are turned down to accomodate the plastic washer if you let me know the overall length of the nut and the diameter and length of the turned section i will make a drawing and we can go from there also is it 17mm or 19mm hex as this dose vary sometimes
cheers
Trev
billytits
Post by billytits » Fri Nov 23, 2007 10:37 pm
more shiney bits that are available
