tc manifold
marinamadman
tc manifold
Post by marinamadman » Wed Sep 24, 2014 6:53 pm
quick question, will a mgb gt exhaust manifold fit on my 72 marina tc? iv busted 5 out of 6 studs so was thinking of just replacing if they fit!
77 marina 1.8 super project
Re: tc manifold
Post by MarinaCoupe » Wed Sep 24, 2014 7:10 pm
The studs are the same as MGB, the manifold itself is slightly different, but will fit, I have one on my SDL Coupe.
enthusiastic youth
Re: tc manifold
Post by enthusiastic youth » Wed Sep 24, 2014 8:29 pm
Not a Direct fit.
This is why:
MGB exhaust manifold.
Marina exhaust and inlet manifold.
(Picture borrowed from Gee tc as an illustration purpose. Hope you dont mind :shifty: )
The TC inlet manifold has two ports underneath so you'll need change both at most.
My cars:
tc manifold
Post by MarinaCoupe » Wed Sep 24, 2014 8:45 pm
They aren't ports running from the exhaust to the inlet manifold, they are extra mounts locking the two manifolds together. This aids heat transfer to the inlet air/fuel mix.
I'll repeat what I said earlier I used MGB manifolds on my SDL Coupe and they work fine.
enthusiastic youth
Re: tc manifold
Post by enthusiastic youth » Wed Sep 24, 2014 8:52 pm
Oh ok, sorry for seaming ignorant...
My cars:
Re: tc manifold
Post by david painter » Wed Sep 24, 2014 8:58 pm
The two extra ports are what Chris says they are called hot spots their funcion is to stop carb icing in very cold damp weather but in the real world its not a problem on the origonal MGB fitment the air filter intakes point towards the exhaust manifold and draws inwarm air accordingly on the origonal TC air filter runs over ther rocker cover and draws cold air from the other side of the engine Hence the need for Hot Spots
Re: tc manifold
Post by MarinaCoupe » Wed Sep 24, 2014 9:06 pm
No probs, we all learn as we go along.
marinamadman
Re: tc manifold
Post by marinamadman » Wed Sep 24, 2014 11:41 pm
thanks for the advice, will get a new one ordered :)
marinamadman
Re: tc manifold
Post by marinamadman » Sun Sep 28, 2014 10:13 pm
managed to get the manifold so its usable, ordered an mgb down pipe but it seems to sit really low? like 6 inches off the floor, is there any ajustment if i loosen the flange bolts? or will it break the seal?
Re: tc manifold
Post by MarinaCoupe » Sun Sep 28, 2014 10:21 pm
The MGB down pipes are longer. You can fit them (I did) and then take it for a good drive getting it stinking hot and then use a trolley jack under the pipes the ease them up without splitting or denting them.
Re: tc manifold
Post by MarinaCoupe » Sun Sep 28, 2014 10:24 pm
The other option us to buy a NOS Marina TC one at a autojumble or EBay.
GES in Devon make a stainless steel Marina TC version which fits very well and is the right hight. They give a 17.5% discount for club members.
marinamadman
Re: tc manifold
Post by marinamadman » Sun Sep 28, 2014 10:27 pm
i really need to get a membership sorted for here, how much is the stainless system? i did email them but no reply. iv got the exhaust chained up round the gearbox mount at pressent as iv only got the downpipe fitted, i may heat it up with oxyacetaline
