CORRECT/BEST ENGINE OIL? BRANDS?
paul
Post by paul » Sat Feb 27, 2016 11:52 am
Ok, this is driving me nuts! (pardon the pun)
What is the best engine oil for a 1300?
The manual, not a haynes but an Autobook, which shows nothing, i seem to remember 20/50w (conventional?synthetic?)being the right thing, and last time i changed the oil and filter i can't remember what i used or where i got the info from! Also the type of oil, sythethic, semi? conventional. Anyone got any preferred brands they swear by?
Post by MarinaCoupe » Sat Feb 27, 2016 1:11 pm
BL used to recommend Castrol back in the day. The correct viscosity is 20W/50 and it is nearly always mineral. You will struggle to find any these days. I use either Penrite (often sold at car shows and auto jumbles or available direct) or Comma available at my local motor factor. Halfords do a 20W/50 in a steel can, that will do until you can get one of the others.
Post by MarinaCoupe » Sat Feb 27, 2016 1:19 pm
There are also Morris Oils (good name) and Millers which also has a good reputation.
This company sells all of them including Castrol by mail order and at shows.
http://www.classic-oils.net
Do a search for 20W/50 and all the brands come up.
Post by MarinaCoupe » Sat Feb 27, 2016 1:21 pm
I used to like Duckhams but it's no longer available, the smell and the green colour were great.
Millers & Penrite both list a 20W/50 synthetic and semi-synthetic oil for high performance engines.
Re: CORRECT/BEST ENGINE OIL? BRANDS?
Post by balmy » Sat Feb 27, 2016 2:30 pm
I use millers in my TC.
Post by JoshWard » Sat Feb 27, 2016 3:06 pm
I use Morris (of course!). Mainly because it's easily available in five gallon drums so does well if you have a whole fleet :lol:
Post by david painter » Sat Feb 27, 2016 3:42 pm
When I worked in the Main Dealer back in the day we used to use BP 15w50 in all cars apart from Rover V8 this engine used to run on Shell 20w50. Today I would use Morris classic motorsport oil in 15w50 mainly because its very good quality and is refineded by my workshop in Shrewsbury
Post by JubileeNut » Sat Feb 27, 2016 9:04 pm
I use Castrol Classic oils delivered to my door. Got a big drum of it last time :D
Castrol still do all the oils correct for your car.
Post by Kilroy » Sun Feb 28, 2016 4:35 am
Long answer = purely my opinion - but with the logic that supports my theory.
The A and B series engines were manufactured using the technology and manufacturing practices of the era.
The recommended oil viscosity had to do with both current oil technology, and machining tolerances.
Your engine when new required an oil of 20 grade to allow adequate pressure to be maintained in the plain bearings - whose entire design depends on this pressure to avoid destruction.
Now that most engines are worn to varying degrees, I would consider using any oil of lesser viscosity (10 or 15..) to be a serious risk.
The "50" part of the rating has to do with the behaviour of the oil when hot - so a 20W/60 works better than a 20W/50.
I admit that in a cold climate, a lesser viscosity oil will perform ok when things are close to freezing - but when your engine and thus your oil get hot - you will have a problem maintaining correct oil pressure.
Most conventional 4 stroke engines of this era suffered most wear when starting from cold - for several reasons.
Cold oil is thicker and thus resists circulating as readily.
Some parts of your engine rely on oil mist or splash for lubrication and this does not exist until the engine has been running for some minutes.
For this reason I decided to use synthetic oil - as it tends to remain more fluid in cold conditions, and thus circulates better from cold starts.
It also retains its lubricating properties better as it ages, so it tends to stick to running surfaces better until the next use.
If I were using a conventional oil I would find a 20W/60 from a reputable brand, and change it at the periods recommended by the car manufacturer.
Instead I use a fully synthetic 20W/50, and because it costs a lot more, I tend to delay my oil changes somewhat - our NZ climate is a little more forgiving.
I have a B series engine that has been in use since my first Marina build in 1996.
It has been bored out to 1905cc and runs 11.5/1 compression ratio, runs through a factory BW65 auto trans, has had several camshaft profiles and still runs the twin SU HS4's.
This engine has now travelled around 250,000km on synthetic oil and does not smoke or use significant amounts of oil between changes.
The first body - a Mk3 estate - basically rotted off it, so I moved the entire powertrain into a Mk3 saloon which is currently heading for the same fate.
Whilst the sheet metal is giving up the ghost, I have made virtually no impression on the engine, and I credit this to synthetic oil.
My driving style is considered in that I know what I am doing to the mechanical parts of my car by how I drive it - but I use full throttle quite often, and this engine is a blast to be in charge of. It has tremendous torque and is impossible to avoid losing rear wheel traction if you are in a hurry.
I do not think this engine could ever have lasted so well without having had a staple diet of synthetic oil - not just because the oil performs better - but also because my oil changing frequency has been rather remiss.
I have 12 vehicles and I just cannot keep my maintenance up to date - it would take my entire daily life to do so.
The oil I use is Mobil 1 Vee Twin. I discovered it when looking for the highest spec oil suitable for my 1975 Triumph Trident which I have owned from new.
This oil has a high level of zinc which is most important for engines with conventional cam followers, and yet is being increasingly left out of modern oils.
So - I guess I am saying that I think this is the best oil for your car - and I think I have proved its effectiveness.
stoterstangen 90
Post by stoterstangen 90 » Sun Feb 28, 2016 4:51 pm
I use Mannol 20w50
Last edited by stoterstangen 90 on Mon Feb 29, 2016 9:50 pm, edited 1 time in total.
Post by marina12 » Sun Feb 28, 2016 5:04 pm
Used Castrol- GTX? - 20/50 in the 80s with oil and filter change every 2000 miles.
Post by david painter » Sun Feb 28, 2016 6:03 pm
Castrol Do a modern synthetic at 10w60
Post by ClaytonSpeed » Sun Feb 28, 2016 9:09 pm
Penrite Oil do a 15w60 Fully Synthetic - I buy through Classic Oils.
Post by MarinaCoupe » Sun Feb 28, 2016 10:06 pm
Hi Paul,
I bet that you regret asking now, don't you?
Post by locost_bryan » Sun Feb 28, 2016 11:28 pm
Hmm, some interesting points raised.
Option 1 the "classic" mineral oil Castrol GTX 20W50 on sale $18.99 (normally $35.88)
Option 2 the "proven" synthetic oil Mobil One Vee Twin $34 per litre :o (there must be a cheaper source and bigger containers)
Surprisingly, Mobil recommend mineral oils for the Marina 1800 http://www.mobil1.co.nz/products/alr.aspx MOBIL 1 0W-40 or MOBIL SUPER 2000 X2 10W-40 ($39.98) or MOBIL SUPER 1000 20W-50 ($29.98)
And I found a local supplier for Morris oils Morris Golden Film SAE 20W-50 Classic Motor Oil 5L $46
