1.8tc exhaust downpipes
Pan
Post by Pan » Thu Jan 12, 2017 8:25 pm
Can anyone tell me if mgb downpipes can be used on a TC?
Cheers,
Mark
Post by MarinaCoupe » Thu Jan 12, 2017 9:25 pm
At a pinch, they are a little deeper (bottom to closer to the ground), so they don't line up perfectly.
You can fit it and then run the engine v hot and then get a jack under the rear of the downpipe and lift it up gently to the required position. Then turn the engine off and let it all cool down.
Re: 1.8tc exhaust downpipes
Post by Gee tc » Thu Jan 12, 2017 11:54 pm
They are also longer from the lower bends to the Y joint. I had one in stainless but faced with the modifications needed, I gave it away to a mate with an mgb.
