Early marina brakes
Keith Anderson
Early marina brakes
Post by Keith Anderson » Thu Feb 23, 2017 4:02 pm
Hi all ,I have a January 1972 1.3 coupe that I am restoring and I need to know what type of front and rear wheel cylinders or repair kits I need there appears to be two types my chassis number is 46762 so am I right in thinking I need the early type?
Re: Early marina brakes
Post by MarinaCoupe » Thu Feb 23, 2017 5:23 pm
Josh will be along shortly, he's the early car man.
Post by JoshWard » Sat Feb 25, 2017 8:01 am
Hi Keith, good to see you on here. Yes you need the early type. The early front wheel cylinders are 19mm- same as Triumph Herald and Anglia 105E. They are available new. You need early shoes as well, usually available on eBay. Rear cylinders on early drum/drum cars are 17.5mm. Same as disc/drum cars from late 72 to 1980. Again these are available new.
Keith Anderson
Post by Keith Anderson » Sun Feb 26, 2017 5:31 pm
Cheers Josh I realised that the front cylinders were the same as my anglia after I took them off,thanks for the info on the rears
Post by Gee tc » Mon Feb 27, 2017 8:46 pm
On my early car the rear cylinders are dolomite sprint and shoes same as escort mk1. It's a TC so may differ
Post by JoshWard » Mon Feb 27, 2017 9:42 pm
Early 1.8s and TCs had different sized wheel cylinders and were auto adjust.
Post by marina12 » Wed Mar 01, 2017 1:22 pm
Post by JoshWard » Wed Mar 01, 2017 7:27 pm
As it says in the listing, those ones are for 1973-1975 models. Early ones had different shoes and cylinders
http://www.ebay.co.uk/itm/Front-Brake-S ... SwdGFYqFGk
Post by marina12 » Wed Mar 01, 2017 7:31 pm
Thanks- shows me how many different variations of components there were.
