6 cylinder Marina upright,disc,hub
Re: 6 cylinder Marina upright,disc,hub
Wow, quite a substantial difference in the bottom joint and where the caliper mounts.
UK leg (courtesy of Kilroy) vs Aussie leg.beniboyz wrote:Wow, quite a substantial difference in the bottom joint and where the caliper mounts.
Other Aussie differences are the "I-beam" has been turned 90 degrees, and the steering arm curves up (the rack was raised 30mm iirc).
Ben this is how yours will turn up.As you can see the hub & upright weighs in at 8kgs.Times this by 2 packaging @ 18-20 kgs.
Marina 6 one day,V8 the next
Maybe i should rent a container on a freight boat at this rate!
I took them to work & gave them a sandblast to get rid of grease & build up,that saved 3kgs.
Good solution Ben.
Will UK trunnions and top ball joints fit or will you be using Aussie ones?
Sent from my iPhone
Sent from my iPhone
Looks like the trunions are gonna have to be Aussie spec. Not sure about the ball joints.
Ball joints are supposed to be the same.
Can you get new trunnion shaft & sleeve kits ?
These uprights were apparently used in the South African v8 rally car.
We don't have sleeve kits over here. They do a larger trunion kit that has its own sleeve that would "repair" a UK leg. They wouldn't suit the Aussie one I wouldn't think. Unless it could be fitted without its sleeve.. Interesting thought..dazza2623 wrote:Ball joints are supposed to be the same.
Do you have any measurements on the kits so I can check.We can always live in hope.
I will have a look to see if I have one to hand.
