Pickup seats
Pickup seats
Hi all,
I have a pickup which is nearing completion with non original seats in. If I can purchase the two seats I will be happy . Can anybody tell me what else Marinawise they are fitted in ? Its a mark one by the way. Thanks , Chris .
Pickup seats
Hi Chris
I have a very good original black vinyl tipping passenger one from my Ital Pickup - complete and ready to bolt in. I also have the frame and cover, but no sponge seat squab for the drivers side. The drivers black vinyl cover has various scratches and rips it's solid but best described as tatty. You should be able to source a sponge seat squab from your existing seats.
Re: Pickup seats
Wey hey , that was quick ! I see you are in Bedford . I,m in Boston so not a million miles apart. I can get over anytime its bad weather ! If you pm me your phone No I will contact you . Mine is 07866 430861.
Many thanks, Chris .
Pickup seats
You have a PM. In the meantime post some pics of your Pickup so far to keep us all interested.
Pickup and Van seats didn't change much at all between the first Mk1 and the last Ital, they were always black vinyl. The one exception was the Van with L trim which amounted to dark grey cloth seats and an extra sun visor.
If you check the documents section on here you will find the BL brochures for all the Commercials and can check exactly what the interior should look like.
Here's my Pickup.
Here's my Pickup.
Re: Pickup seats
Your pickup looks great , especially like the wheels . I don't have a clue why my picture turned sideways !!
Re: Pickup seats
Your Mk2 looks lovely, I'm using Tapatalk on my iPhone and your picture is the correct way round.
Re: Pickup seats
My Ute
1978 Pageant Blue 1.3 Special
1982 Morris 575 pickup
1982 Mini 1000 HLE
1988 CBR 400rr baby blade
1955 James captain 197cc
1977 Antic Weslake
"ON A SPECIAL MISSION"
1982 Mini 1000 HLE
1977 Antic Weslake
Re: Pickup seats
Another cracker and some more nice wheels !
Re: Pickup seats
Hey Chris , I'm glad you told me its a mark two . I thought it must be a mark one . I'm a learning !!
Re: Pickup seats
If you can PM me the reg no and chassis number I can verify that. Did you get my PMs.
Re: Pickup seats
No pm's . Ex MOD so Reg is Q523 YAW and chassis No SABTVR03969051031 .
Be interesting , Thanks . Chris .
Pickup seats
I can't find any records starting with that code at all. Possibly because it's ex MOD.
I based my identification as a Mk2 based on the front bumper and sidelight/indicators. Mk3s are different. The grill you have used is from a Mk2 1.3 saloon or coupe. The Mk2 grill should be the same as a Mk1, with the split grills and the vertical centre nose, check the brochures the link is below.
Chassis numbers should start as follows,
Mk1s normally start with M/AU9H or YAU9H
Mk2s normally start with YE2UKH
Mk3s normally start with LE2UKH
Here is the link to the brochures.
index.php?option=com_jfusion&Itemid=12& ... m.php&f=30
Re: Pickup seats
The body is as I bought it Chris. The front suspension has been changed for the 1.8 I would think as it has discs fitted and 14 inch wheels whilst the rear are drum and 13 inch . So another requirement will be one of each for spares !! The chassis plate appears made up so would imagine the MOD had it without one and DVLA invented one when it was first registered on civvy street . Chris .
Pickup seats
Disks were an option, and standard from Nov 1978, all original Pickups came with the heavy duty front and rear suspension. 1.8 saloons and coupes used the same softer spring rate as the 1.3 saloons and coupes. If you swap the front 4.5" PCD hubs to saloon 3.75" PCD hubs you will have the same stud pattern all round. This is what is on Barmy's white Pickup.
My Pickup is on the original 4.5" PCD hubs front and rear.
