Brake shoes
Lecozens
Brake shoes
Post by Lecozens » Fri Jul 22, 2016 8:52 pm
Hi All,
I'm planning to change my brake shoes this weekend as I've had enough of squeeky brakes. However I've just inboxes the shoes I brought and not sure if they are the right ones... due to go onto a Mk1 1.3 saloon.
Are these the right ones?
Lewis
Re: Brake shoes
Post by MarinaCoupe » Fri Jul 22, 2016 9:07 pm
Have you got part numbers and are they for the front or rears?
Lecozens
Re: Brake shoes
Post by Lecozens » Fri Jul 22, 2016 9:14 pm
Sorry that would of helped....
They are supposed to be for the front. I believe they are gbs162
Regards
Lewis
Re: Brake shoes
Post by MarinaCoupe » Fri Jul 22, 2016 10:51 pm
Josh or AquaMarina will be the best to advise.
Re: Brake shoes
Post by JoshWard » Sat Jul 23, 2016 8:01 am
The changeover for the front shoes was chassis number 291007 to 295000 & 302538 onwards. If your chassis number is below 291007 you will probably need the earlier type.
Lecozens
Re: Brake shoes
Post by Lecozens » Sat Jul 23, 2016 8:07 am
Silly question, how do I find my chassis number?
Re: Brake shoes
Post by david painter » Sat Jul 23, 2016 9:37 am
On V5c or on a plate on the bonnet slam panel usually
Lecozens
Re: Brake shoes
Post by Lecozens » Sat Jul 23, 2016 11:19 am
I feared that was it... wrong shoes then
On a brighter note anyone need some shoes? Can bring bl day
aqua-marina
Re: Brake shoes
Post by aqua-marina » Sat Jul 23, 2016 1:53 pm
JoshWard wrote:The changeover for the front shoes was chassis number 291007 to 295000 & 302538 onwards. If your chassis number is below 291007 you will probably need the earlier type.
As josh says you probably need a set like these
Lecozens
Re: Brake shoes
Post by Lecozens » Sat Jul 23, 2016 2:04 pm
Have ordered a new set, like the ones you posted aqua marina. Another week of squeeky brakes it is then :(
Just to double check, the correct ones are the same as an escort mk1/2?
Martec
Re: Brake shoes
Post by Martec » Mon Jul 25, 2016 8:49 am
A squeel from the brake shoes is often either a build up of dust inside the drum (it can't get out), or the leading edge of the shoe making the noise.
1 - take off the drum and clean it out by dropping the dum face down on the concrete about 4"/100mm.
2 - use a file and bevel the leading edge of the two shoes at about 45 degrees for about2mm.
3 - use coarse sandpaper or similar and scuff the surface of the pad to get rid of the shiney surface.
Cheap and easy.
Best of luck
Shopping trolley(Mazda3)
Lecozens
Re: Brake shoes
Post by Lecozens » Mon Jul 25, 2016 5:40 pm
Not sure I'd be happy dropping the drum....
Re: Brake shoes
Post by MarinaCoupe » Mon Jul 25, 2016 6:19 pm
From 4" - just make sure it's square on flat to the surface.
Re: Brake shoes
Post by david painter » Mon Jul 25, 2016 6:26 pm
I would invest in a can of brake cleaner, much safer no distorted drum and no dust. Only a couple of quid. As already said clean out dust. Chamfer shoes and clean up with 80grit production paper. Lubricate all contact points on back plate and wheel cylinders ( not getting on lining) with copper grease or similar then re adjust.
aqua-marina
Re: Brake shoes
Post by aqua-marina » Mon Jul 25, 2016 7:28 pm
Lecozens wrote:Have ordered a new set, like the ones you posted aqua marina. Another week of squeeky brakes it is then :(
GBS814 unipart shoes up to chassis no
302537
Same shoe fits various fords and vauxhalls
