Brake shoes
Brake shoes
Hi All,
I'm planning to change my brake shoes this weekend as I've had enough of squeeky brakes. However I've just inboxes the shoes I brought and not sure if they are the right ones... due to go onto a Mk1 1.3 saloon.
Are these the right ones?
Lewis
Lewis
Re: Brake shoes
Have you got part numbers and are they for the front or rears?
Re: Brake shoes
Sorry that would of helped....
They are supposed to be for the front. I believe they are gbs162
Regards
Lewis
Regards
Lewis
Re: Brake shoes
Josh or AquaMarina will be the best to advise.
Re: Brake shoes
The changeover for the front shoes was chassis number 291007 to 295000 & 302538 onwards. If your chassis number is below 291007 you will probably need the earlier type.
Re: Brake shoes
Silly question, how do I find my chassis number?
Re: Brake shoes
On V5c or on a plate on the bonnet slam panel usually
Re: Brake shoes
I feared that was it... wrong shoes then
On a brighter note anyone need some shoes? Can bring bl day
aqua-marina
Re: Brake shoes
As josh says you probably need a set like theseJoshWard wrote:The changeover for the front shoes was chassis number 291007 to 295000 & 302538 onwards. If your chassis number is below 291007 you will probably need the earlier type.
Re: Brake shoes
Have ordered a new set, like the ones you posted aqua marina. Another week of squeeky brakes it is then
Just to double check, the correct ones are the same as an escort mk1/2?
Re: Brake shoes
A squeel from the brake shoes is often either a build up of dust inside the drum (it can't get out), or the leading edge of the shoe making the noise.
1 - take off the drum and clean it out by dropping the dum face down on the concrete about 4"/100mm.
2 - use a file and bevel the leading edge of the two shoes at about 45 degrees for about2mm.
3 - use coarse sandpaper or similar and scuff the surface of the pad to get rid of the shiney surface.
Cheap and easy.
Best of luck
Cheap and easy.
Best of luck
Shopping trolley(Mazda3)
Re: Brake shoes
Not sure I'd be happy dropping the drum....
Re: Brake shoes
From 4" - just make sure it's square on flat to the surface.
Re: Brake shoes
I would invest in a can of brake cleaner, much safer no distorted drum and no dust. Only a couple of quid. As already said clean out dust. Chamfer shoes and clean up with 80grit production paper. Lubricate all contact points on back plate and wheel cylinders ( not getting on lining) with copper grease or similar then re adjust.
aqua-marina
Re: Brake shoes
Lecozens wrote:Have ordered a new set, like the ones you posted aqua marina. Another week of squeeky brakes it is then
GBS814 unipart shoes up to chassis no
302537
Same shoe fits various fords and vauxhalls
