rear screen rubber coupe
crashbang
Post by crashbang » Sun Aug 25, 2013 5:32 pm
So been having a job getting one of these and in the end having talked to east Kent trims I sent off the old one to them for patan and thay sent back the best mach but I still had to cut it down I have some picture of how I made it fit but can't make them go on the screen but give me your email and I will send them to you
LIL1937
Re: rear screen rubber coupe
Post by LIL1937 » Sun Aug 25, 2013 6:55 pm
Hi Craig, Thanks for getting back to me today regarding the above, just wanted to confirm the screen rubber they sent you as I'm sure someone said mk3 Ford Escort front but when I contacted Kent trims they said you had used a mk2? so just a bit confused that's why I wanted to check with you!
I'll forward my e mail address to you if you would kindly send pics and if anyone else can confirm which one has been used before please, One of my coupes is getting near completion so will need it soon,
Got pics of the coupe but not sure how to post pics if anyone can advise please, Thanks
Andy
Post by minispeedstar » Sun Aug 25, 2013 8:54 pm
I was looking at a mk2 cortina rear window the other day thinking that might work too?..
Post by ClaytonSpeed » Sun Aug 25, 2013 9:07 pm
Just use the MK3 escort front rubber, cut in half and spliced together. . Any competent Windscreen tech should be able to help. :)
crashbang
Post by crashbang » Mon Aug 26, 2013 10:04 am
I don't. Know what the rubber was from but it cost me £50 I tried to send the picture but it bounced back so I will try to make them go to the forum if not I see if i can get it on fb page
Post by JoshWard » Mon Aug 26, 2013 1:58 pm
Does the SDL/TC windscreen trim fit in the MK3 Escort rubber then?
crashbang
Post by crashbang » Mon Aug 26, 2013 2:58 pm
Its just a filler strip
LIL1937
Post by LIL1937 » Mon Aug 26, 2013 9:26 pm
JoshWard wrote:Does the SDL/TC windscreen trim fit in the MK3 Escort rubber then?
Hi Josh
I believe that as long as it has the filler strip groove you can make the original stainless trim fit, but its a struggle with the original to get it in let alone the wrong rubber!
beniboyz I've a competent screen fitter to do the job just trying to get best info before we start! do you meen cut rubber in half? ie top and bottom and splice together? or just cut the top and shut? I guess the only way is to get one and try but there was a bit of confusion whether it was mk1 or mk2 Escort?
Cheers for now Andy
Post by MarinaCoupe » Mon Aug 26, 2013 9:31 pm
I thought that it was a Mk3 Escort. Fruity did the first one hopefully he can confirm what and how?
crashbang
Post by crashbang » Tue Aug 27, 2013 8:47 pm
Yep cut top and bottom I have put pictures up on the marina Facebook page coz I can never get pictures to work on forum :-?
Post by fruity » Tue Aug 27, 2013 11:52 pm
Hi guys, yes it was a Mk3 escort front screen seal, as mentioned it was just cut in two places and put on its a great fit with "No leaks!!" So I can confirm it does work! ;)
Sent from my (Batfone)
74 Tundra Coupe
74 TC " Jubilee "
LIL1937
Post by LIL1937 » Thu Aug 29, 2013 7:33 pm
fruity wrote:Hi guys, yes it was a Mk3 escort front screen seal, as mentioned it was just cut in two places and put on its a great fit with "No leaks!!" So I can confirm it does work! ;)
74 Tundra Coupe
74 TC " Jubilee "
Hi Fruity,
Thanks, I have now received a mk 3 Escort screen rubber to do the job! I'll let you know how we get on,
Andy
